手风琴触灯可以在灯和台灯之间交替使用!
原标题:手风琴触摸灯可以在灯笼和台灯之间交替使用! 文末提供翻译
PR Design’s Accordion Touch light is as playful as it is inventive! It uses a light source and a collapsible accordion-style shade that can be used to convert the light from a focused table-lamp to a more diffused lantern. The light, aside from having a dual-arrangement, also features a wooden handle that also supplements as a stand!
The Accordion Touch Light comes with a touch-sensitive switch on the back of the light-module and can be used to easily (and gently) switch the light on or off without knocking it over. Keep it on your desk for a focused light, or your bedside table for a warm diffused glow, or even carry it around like a flashlight, the battery-powered Accordion Touch Light is sure to add a touch of brightness to spaces as well as lives!
Designer: PR Design
Click Here to Buy Now
P_R设计的手风琴触摸灯既有趣又富有创造性!它使用一个光源和一个可折叠的手风琴式灯罩,可以用来将光线从聚焦的台灯转换为更分散的灯。这盏灯,除了有一个双重的安排,还具有一个木制的把手,也作为一个补充立场!手风琴式触摸灯在灯模块的背面带有一个触摸感应开关,可以轻松(轻轻)打开或关闭灯,而不会将其打翻。把它放在你的桌子上作为聚焦灯,或者放在你的床头柜上作为温暖的漫射光,或者像手电筒一样拿着它到处走,电池供电的手风琴触摸灯肯定会为空间和生活增添一点亮度!设计师:P_r Design单击此处立即购买单击此处立即购买
