再生文物
原标题:Recycled Relic Lighting 文末提供翻译
foam_01
The Foam Cloud project consists of three “clouds of light” located at three different points in the exhibition space at the Photography Museum of Amsterdam (FOAM). Beautifully basic, it’s simplicity is the result of a very limited budget!
To keep within the confines of this budget, 42 fluorescent lamps were recovered from the museum warehouse. These reused lamps were given new life as the sole material in the project, reducing the cost to zero!
At first glance, the design of the “clouds” seems chaotic, arbitrary and random. However, the position of the lights is actually quite precise. At an external point of view (marked on the pavement of the street), the name of the museum – FOAM – is drawn in the air. As the pedestrian moves or loses this vantage point of view the light changes, establishing a fun visual play between the indoor installation and the exterior observer and thus, between the museum and its potential visitor.
Designer: Francisco Colom Jover
foam_02
foam_03
foam_04
foam_05
foam_06
foam_07
泡沫云项目由位于阿姆斯特丹摄影博物馆(泡沫)展览空间的三个不同点的三个“云光”组成。基本的漂亮,简单是预算非常有限的结果!为了保持预算内的限,从博物馆仓库中回收了42盏荧光灯。这些重使用的灯被赋予了新的生命作为唯一的材料在项目中,降低成本为零!乍一看,“云”的设计似乎是混乱的、随意的和随机的。然而,灯光的位置实际上相当精确。在一个外部的角度(标记在街道的人行道上),博物馆的名字——泡沫——被画在空气中。As the pedestrian moves or loses this vantage point of view the light changes, establishing a fun visual play between the indoor installation and the exterior observer and thus, between the museum and its potential visitor.Designer: Francisco Colom Jover
