蜻蜓证触觉开关不会去任何地方
原标题:Dragonfly proves that tactile switches aren’t going anywhere 文末提供翻译
dragonfly_switch_1
While companies are investing in voice-assisted homes where you can simply control lights by talking to them, New Deal Design’s Dragonfly switches (developed exclusively for Dragonfly Investment Group’s properties) show that tactile controls can and will always provide an experience that’s much more relatable and fulfilling to a user. Deviating from the traditional concept of switches, Dragonfly relies on touch-sensitive switchboards and a connected system that lets you intuitively control your lights.
The switchboards feature a backlit display with different columns for different rooms in the house. These columns are ‘filled with light’ and can be dragged up or down, adjusting the room’s brightness by simply quantifying light itself. Sliding your finger upwards along the column lets it fill up with light, and makes the room in question brighter. Individual columns control individual rooms, and Dragonfly switchboards are placed in every room, allowing you to, from wherever you are, control all the lights in your home. So you don’t need to go to the kitchen to A. notice that the lights are on, and B. switch them off… you can do that from your bedroom itself, or any other room in the house. The animated display makes controlling your lights intuitive, and much more fun than telling Alexa to switch your lights on or off. It provides visual feedback that completes the experience for the user. What’s more is that Dragonfly can be automated to follow broader tasks too, like switching off all the lights when you leave your home!
Designer: New Deal Design for Dragonfly Investments Group
dragonfly_switch_4
dragonfly_switch_5
虽然公司正在投资于语音辅助住宅,在那里,你可以简单地通过与他们交谈来控灯光,但新政设计的蜻蜓开关(专门为蜻蜓投资集团的财产开发)表,触觉控可以,而且将永远提供这样的体验CH对用户更可满足和满足.与传统的开关概念不同,蜻蜓依靠触敏开关板和连的系统,让你直观地控你的灯。.这些柱子是“充满光线”的,可以上下拖动,通过简单地量化光线本身来调节房间的亮度。.你的手指沿着柱子向上滑动让它充满光线,使房间变得亮。.所以你不需要去厨房.注意灯亮了,B.把它们关掉……你可以从卧室本身或房子里的其他房间里做。.动画显示使你的灯光控直观,比告诉Alexa打开或关闭灯有趣得多。.它提供视觉反馈,为用户完成体验。.更重要的是,蜻蜓可以自动执行更广泛的任务,比如当你离开家时关掉所有的灯!设计师:蜻蜓投资集团新政设计
