无人机灯将引导你回家
原标题:Drone lights will guide you home 文末提供翻译
twinkle_drone_1
The idea seems wild, but the more and more you think about it, the more it begins making sense, and seems more plausible than before. The idea behind the Twinkle is to combine drone tech and illumination to make the world’s smartest and most useful street-lights.
Each individual street-lamp would be a vertical pole with multiple Twinkle drones docked in it. The drones would come with powerful lights at their base, illuminating the land right underneath them, and when docked in their lamp-posts, would look just like any streetside lamp. However, as soon as pedestrians pass from underneath, a single Twinkle drone would leave its dock and follow the pedestrian(s) around, lighting their path. This individual lighting solution would mean no dark alleyways or blind-spots for pedestrians, as they quite literally have a guiding light with them. If a Twinkle’s battery reached critical status, it would head back to its dock and send another Twinkle on the way.
A floating street-light goes far beyond making streets safer. Its ability to move allows it to patrol streets, alleys, and even off-road paths where you probably wouldn’t find any lights. The Twinkle drone helps guide you from A to B, rather than rely on a string of streetlights to illuminate your path. When done, it goes back to its dock, transforming back into your regular streetlight!
Designers: Honghao Deng & Jiabao Li.
twinkle_drone_2
twinkle_drone_3
twinkle_drone_4
twinkle_drone_5
twinkle_drone_6
这个想法似乎很疯狂,但是你想的越多,它就越有意义,而且似乎比以前更可信。.Twinkle背后的想法是结合无人机技术和,造世界上最智能、最有用的路灯。每个路灯都是一个竖杆,上面停放着多个Twinkle无人机。.无人机底部会装上强光灯,亮下方的土地,当停靠在灯柱上时,看起来就像任何路边灯。.然而,一旦行人从下面经过,一架闪烁无人机就会离开码头,跟随周围的行人,亮他们的道路。.这个单独的解决方案意味着行人没有黑暗的小巷或盲点,因为他们实际上有一个引导灯。.如果Twinkle的电池达到临界状态,它就会回到码头,在路上再发送一个Twinkle。.它的移动能力允许它巡逻街道,小巷,甚至越野路径,你可能找不到任何灯。.闪烁的无人机帮助引导你从A到B,而不是依靠一串路灯亮你的路径。.当它完成后,它回到它的船坞,转化为你的常规路灯!设计师:洪浩登与贾宝丽
回复数 4 切换时间排序
