一个偏心的电线灯!
原标题:An Eccentric Electric Wire Lamp! 文末有翻译
diy_lamp_111
The very thing that delivers electricity to this lamp, is what makes this lamp! The unusual use of electrical wiring as a design element is what makes the Coil Lamp such an unusual beauty.
Simply using two intersecting pieces of laser cut acrylic as its framework, the 100ft extension wire coils around this framework, becoming the lamp itself! “This simple transformation elevates the status of the humble extension cord to the realm of domestic design” says designer Craighton Berman.
The Coil Lamp is a permanent exhibit at the Art Institute of Chicago and can be purchased below. However, if you’re looking to buy the DIY version to build on your own, you can get one for a cheaper price right here! It comes without the 100ft extension, allowing you to choose your own colored wire!
Designer: Craighton Berman Studio
BUY IT HERE: $199 (Fully Assembled)
diy_lamp_2
diy_lamp_3
diy_lamp_4
diy_lamp_5
diy_lamp_6
diy_lamp_7
diy_lamp_8
把电送到这个灯的正是这盏灯的造方式!电线的特殊用途是一个设计元素,这就是为什么线圈灯是一个不寻常的美丽。简单地使用两个交叉的激光切割丙烯酸片作为框架,100英尺延长线绕这个框架,成为灯本身!“这个简单的改造提升了简陋的延长线的地位,进入了国内设计领域。”设计师Craighton Berman说。盘灯是芝加哥艺术学院的永久性展品,可以在下面购买。但是,如果你想购买DIY版本自己作,你可以在这里买到一个更便宜的价格!它没有100英尺的扩展,让你选择你自己的彩色电线!设计师:Craighton Berman StudioBUY在这里:199美元(完全组装)
