一盏奇妙的大理石灯!
原标题:A Marvelous Marble-ous Lamp! 文末有翻译
Marble is luxurious, elegant, and expensive. However, it also leaves a massive amount of waste when operated upon that is cheap, and can be used rather cleverly. Marble dust. Marble dust is rich in calcium, and is usually disposed of by most, with a few exceptions.
The Marble Lamp by Selce Studio uses marble dust’s semi-opaque quality to serve as a pretty innovative light diffuser. A transparent box with a bulb placed strategically on one surface is filled with marble dust. Depending on how you position the box, and how the marble dust lies within it, the dust blocks or lets through light. You can play with the degree of coverage to make the light dimmer or brighter. You can even use the dust to position the light and have it facing any which way you want it.
Playful, check. Aesthetic, check. Inventive, check!
Designers: Riccardo Centazzo & Jaxon Pope (Selce Studio)
BUY NOW
marble_lamp_1
marble_lamp_2
marble_lamp_3
marble_lamp_4
marble_lamp_5
marble_lamp_6
marble_lamp_7
marble_lamp_8
BUY NOW
大理石豪华、典雅、昂贵。然而,它也留下大量的废物操作时,这是便宜的,可以使用相当巧妙。大理石粉尘。大理石粉尘含有丰富的钙质,通常被处理掉,除了少数例外。SelCE Studio的大理石灯使用大理石灰尘的半不透质量来作为一个相当创新的光漫射器。一个透的盒子,其中有一个灯泡放置在一个表面上。取决于你如何定位盒子,以及大理石尘埃是如何位于其中的,灰尘阻挡或让光线通过。你可以玩覆盖度,使光线变暗或亮。你甚至可以用灰尘来定位光线,让它面对你想要的任何方式。审美,检查。发,检查!设计师:Riccardo Centazzo和Jaxon Pope(SelCE Studio)现在购买NoYBuy
