线性高压IC方案特点:Linear high-voltage IC program Features:**电路简单,外围元件少,适合做成光源电源一体化产品,生产工艺简单,生产效率更高;**Simple Circuitry, Reduce components used, Easy integration to various lighting products, simple and efficient production process; **无需高频变压器、电感和大容量电解电容,寿命更长久;**No high-frequency transformers required, No inductors and large electrolytic capacitors, result to longer lifespan; **谐波低,满足EMC认证的需求,满足无频闪灯具的设计;**Low harmonic distortion results to no flickering Meeting EMC certification requirements; **IC内部智能控制,具备过温调节和过温保护功能;**Built in Internal Intelligent Control IC providing overheat (OHT) protection;**The unique feature of the IC's function is the Input Voltage management function. It is suitable to design in lighting products where the input AC voltage supply is unstable; **OVP过压调节功能,是本IC最大亮点,可以满足灯具在市电较为不稳定或长期电压偏高地区安全地工作;**材料成本和人工成本大大降低,LED产品取代传统照明,LED照明步入平民化时代即将来临;**Significant reduction in Manufacturing Costs (Material, Labor and Time).LED Lightings has entered to our Life, Time to make them Affordable and more efficient!
